Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
First time using the AC. Won't go on. Heater works.
Carrier Infinity model #24ANA1. Thermostat model goes w/ system. Says: "Curtailment Active." Fan on auto, Cool. Temp set lower than ambient temp. Fan in house works, but fan outside won't turn on. First time using AC. Brand new as of Oct. 08. Furnace works fine. Breakers are on.
Steaming in Baltimore!
  • 55 Answers
Lower temp setting lower then outside temp should work
Posted on Aug 06, 2009
SOURCE:
Nordyne E1EB 012HA, outside unit would only come on at times when kicked if it didn't run normally. The Honeywell Programmable thermostat has Cool On I have tried to reset it also but it stays on.
First of all, fan on the tstat (on or auto) is referring to the blower fan not the outdoor fan. For the outdoor fan to run system must be set on cool and the setpoint temp must then be lower than the room temp. So what you are saying is the unit begins to work when you kick it??? Possibly you have a lose wire somewhere, check all connections outside. What type of checks have you performed on the capacitor?
Aug 01, 2018 | Honeywell Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
I have hooked up all the wires and batteries correctly but the system is still blowing out nothing but cold air and the thermostat is a newly installed system
Check wiring done correctly.
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Helpful?
Jan 04, 2011 | Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Now symbols:
4. Sun- Heat
Jan 03, 2011 | Samsung AW1203B Air Conditioner
Payne AC not working. 1. Thermostat set 68 to AC w/fan on. 2. Breakers and switch near heater are on. 3. Outside unit has 220v but is not running. 4. Fan in heater/Ac unit is not running 5. ...
Dan is this a new system, or has some work on the system (to include the thermostat) been done recently?
Sounds like the thermostat may be wired wrong. From what you describe, the igniter element is coming on, as though you are calling for heating. Do you allow the ignitor to keep going and see if the gas fires off, or are you seeing this and shutting down the system immediately?
If you had the t-stat changed recently, or this is a new system, contact the installing contractor. It may be under warranty.
Sep 03, 2010 | Carrier Heating & Cooling
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have a new Carrier HVAC system with a fancy EDGE thermostat. When I turn the system OFF at the thermostat, and set the fan to AUTO, hours later I will find that the fan is running and it's setting on the...
1. Open the door. 2. Press and hold the buttons underneath the heat and cool setpoints simultaneously (the two bottom buttons on the right) until the screen displays the reset reminders and 01 in the lower right corner. 3. Press the up arrow button until 01 changes to 07 with OF (fan mode) next to it. 4. To turn the fan on, press the rightmost lower button then press the up arrow button until the screen displays ON. To turn the fan off, press the rightmost lower button then press the down arrow button until the screen displays OF (off). 5. Press the done button. 6. Close the door.
Jun 06, 2010 | Carrier 36KCARMS Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
536 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
