Question about Kenwood Food Mixers
When I was making bread in the glass bowl on my Kenwood chef it became detached from its plastic base. I have tried putting it together but nothing seems to work.
4 Suggested Answers
SOURCE:
SOURCE: Kenwood chef 700w
I hope you didn't buy a new one, ours stopped last week after 25 years. All that was needed were new brushes for the motor. Anyone with a screwdriver could replace them. 4Kenwood had the parts to me in a couple of days.
Posted on May 31, 2008
mirran
  • 515 Answers
SOURCE: replacement stainless steel mixing bowl
I have the spare part number for the bowl.
KW638821 - bowl - polished - stainless steel
KW672487 - with handles bowl - mirror finish
try to find a store near you to get one.
Posted on Jul 12, 2008
SOURCE: What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Posted on Jul 10, 2010
Mixer Kenwood Chef too high, tried adj screw
I put an extra plastic circle in the base of my machine as well as doing the adjustment and it worked.
May 29, 2016 | Kenwood Food Mixers
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
Looking for Kenwood bowl 28589 for KM210
Hi, are you after a used or brand new?
Nov 19, 2013 | Food Mixers
Kenwood Chef A901 beaters dont touch the bottom of the bowl. Can you set the mixer lower
Try making up a thin disk or two to put under the bowl to lift it up. Over time the head locking mechanism can wear allowing the head to lift up a bit.
Mar 18, 2013 | Food Mixers
A very old A701A. Spares needed
I have one plastic bowl that I will sell to you for $40 you can contact me on nazak_k @ yahoo.com
Nov 05, 2009 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef Bowl
Check out ebay , often you can find parts for Kenwood
Sep 18, 2009 | Kenwood KM300 Chef Stand Mixer
Does anyone know the model number of a stainless steel bowl to fit the Kenwood Chef KM300/
The model number doesn't really exist other than the fact that the stainless steel bowl is available for just about every Chef made. My own KM300 has a stainless steel bowl for example that came as standard - it however is the same bowl you can order from Kenwood or EBay under the A701/A901 model - all bowls from Kenwood can be fitted on the Chef model with the exception of the Major model which is a larger and taller machine.
May 06, 2009 | Kenwood KM300 Chef Stand Mixer
Replacement stainless steel mixing bowl for kenwood chef A901D
Apr 15, 2008 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
81 people viewed this question
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
