Dishwashers Logo
bill barkley Posted on Feb 27, 2019
I'm getting a E02 error code on a new install Blomberg DWT25502SS model dishwasher Any idea what I can do to fix?
Eitan Bretshnaider
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 02, 2019
Eitan Bretshnaider
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
6389
Points
20
Switch off and unplug the washer.
- Check the fill hose isn't blocked, squashed or kinked.
5 Related Answers
Anonymous
  • 284 Answers
  • Posted on Sep 30, 2008
SOURCE: DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Anonymous
  • Posted on Dec 12, 2008
SOURCE: E02 error message - remove and reattach battery
Read what Juan Carrera wrote about this problem.
http://bellsouthpwp2.net/j/u/juancarrera/JVC/JVC%20Camcorder%20Errors.htm
Anonymous
  • 81 Answers
  • Posted on Jul 07, 2009
SOURCE: Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Anonymous
  • 10 Answers
  • Posted on Oct 22, 2009
SOURCE: hotpoint ultima. recently changed belt but now
Hiya,
F02 is a motor related fault, the correct terminolagy is; motor tacho open/short circuit, check motor/wiring and connections.
The most common reason for this is a bad connection or broken wire or last resort, module.
Remove the lower back panel and you will see the motor wires (white plug) there will be 7 wires, 2 of which are red or black, pull gently on the wires at the motor end, you will probable find one of the red/black wires will come off...
If they are all tight, check the external wires in the motor especially the ones that go to the rear of the motor (tacho) inspect those wires for damage..
Another common one is where the wires plug into the motor, this plastic holder sometimes comes loose and hangs from the motor, if this is the case, secure it back to the motor.
Hope this helps, Please rate my help. Thanks
Regards
Sussex engineer
Anonymous
  • 149 Answers
  • Posted on Nov 19, 2011
SOURCE: How to solve Error Code E02 always appear
Error Code E02 means paper jam.
Solution
1. Unplug the power cord and USB cable.
2. Lift the printer upside down, then shake the printer.
3. This is done, to remove foreign objects, which get into the roller.
Causes of damage
Solution
How to replace the drain pump in a Blomberg dishwasher Model DW14140 NBL
Generic Dishwasher pump replacement videos. Basically, pull it out, tip it on its back, remove hoses, remove electric connector, unscrew fixing screws.
https://www.google.com/search?q=replace+the+drain+pump+in+a+Blomberg+dishwasher+Model+DW14140
Error code IFt on Blomberg DWS54100 Dishwasher
Thanks so much for this information. I have to let you know I concur with several of the points you make here and others may require some further review, but I can see your viewpoint. Custom Soap Boxes
I get error code E02 on blomberg dwt28500 ss dishwasher. What does it mean?
http://www.fixya.com/support/t27245155-getting_e02_error_code_new_install
I have a Blomberg GVN9380 dish washer which is suddenly not working and giving the error 1F. What can we do to fix this please?
Go to repairclinic.com and use the self help section. Enter your model number first to get specific trouble shooting info for your model.
2helpful
2answers
Dishwasher is powered on but and making normal start up noise but no water is entering the dishwasher and not beginning the wash cycle
My Dishwasher is a Blomberg DWT 25200 SSWS. It had the same problem. It powers up but no water enters in it and the clock didn't advance. This is what I did to fix it.
You can display the error code by powering off the dishwasher then pressing the 'Program' and 'Half Load' buttons at the same time then power on the dishwasher. This will show an error on the screen. My error was E:1.
The problem was a disconnected blue hose at the bottom of it.
This is the overflow detector.
This little board has a 12 Volt relay that activates the main water valve which is a 120 VAC valve. There was nothing wrong with it.
This plate is at the bottom of the dishwasher to hold the water that spills.
2answers
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
1helpful
2answers
A Bosch dishwasher indicates E02. This belong to the SMS series. What is the problem exactly?
Hi, welcome to FixYa.
To answer this with much detail will require the entire model number, but typically this error (E02) indicates a failed NTC.
Please verify the number as shown here and we can go from there.
Please post back as to what you find and what you already know, then I can assist you in any manner going forward and I'll certainly be glad to help in any manner I can.
Thanks again for choosing FixYa. I look forward to your reply.
Regards,
Macmarkus :)
Oct 27, 2011 • Dishwashers
Top Blomberg Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
winchester
winchester
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
