Hi.. I would like to know what error code you were getting along with the symptoms and what the display is showing. If you replaced the main board and the evap fan, I am guessing that you had sy ef showing. There is also sy ce which is a communication error between the main control and the display board. If sy ce is showing then most likely both boards will need to be replaced.
This could also be caused by a shorted wire between the two and would need to be checked individually. I like to make sure it is not just a loose harness at the top of the left door just under the trim cap.
Please provide more information so we can help you diagnose the issue. Thanks!
SOURCE: kenmore frige model 59658692890 evap fan will not start
It won't run if unit is stuck in defrost.
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
SOURCE: GE Profile Top-Freezer PTS22LBNARCC Unit was
In order to ensure proper temperatures, you need to permit airflow between the refrigerator and freezer sections. As shown in the illustration, cool air from the refrigerator enters through the bottom of the freezer section and moves upward. Most of the air then flows through the freezer section vents and recirculates under the freezer floor. The rest of the air enters the refrigerator section through the top vent and flows down the back of the refrigerator compartment.
Ensure that none of the air vents are blocked. If an item is placed near a vent, it may block the flow of air to the refrigerator, which may cause temperature and moisture problems. Move the item away from the air vent.
Adding a large amount of food warms the refrigerator. It could take several hours to return to the normal temperature after food is added.
If the refrigerator is in defrost mode, the freezer compartment temperature will be warmer than usual. Allow 20 minutes, and then the freezer should be back in normal cooling mode.
Things to check: The coils underneath clean?
Is the fan in the back running. You can tell if this is not work because the middle wall will be really hot where the doors touch it. Is there frost in the back of the freezer? Do you hear the fan running in the freezer? You will only here it when the compressor is running, this is true also for the fan in the back.
these refrigerators have a damper control basically a motor with a vent that opens when its too hot in the fresh food side and closes when its too cold.its very common for the motors to go out or freeze up at short out then the fresh food side will freeze up because the vent is wide open no matter what setting.
Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
SOURCE: g.e refrig gsh25jre makes a clicking noise refrig
The clicking noise means the computer board is bad. It will have to be replaced.
SOURCE: Samsung refrigerator model #RS2533SW sserial#755843CTA02409
This is a common problem. The situation you mentioned is highly suggestive of faulty control board ( or call as motherboard ). You could try to unplug the refrigerator for few minutes, say 15 minutes and then turn it ON. If you do not see any improvement, it would confirm faulty control board and needs replacement.
However, there were few models in the past which had a reset option where you need to hold the power up and power freeze pads at the same time until their
little lights come on then you press a small square button on the
ice-maker then the compressor and fans start up.
Thanks and Regards
taran_2005
