Question about Hotpoint Washing Machines
My hot point washing machine is flashing code f08
    Top Expert:
  • Hotpoint Master
  • 61,937 Answers
ASK Google
Posted on Feb 27, 2019
SOURCE:
  • 8 Answers
SOURCE: Indesit WIE127 Washing machine which
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Posted on Jul 30, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Posted on Dec 17, 2008
  • 6277 Answers
SOURCE: Hi I have a hotpoint
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Posted on Mar 09, 2011
HansPP
  • 2510 Answers
SOURCE: Whirlpool washing machine showing a code of F08
That is an overflow condition.
Check the drain hose and make sure it is not plugged or kinked
Check the wire harness to the drain pump, pressure switch and Central Control Unit
Check and clean the drain pump filter of foreign objects
Check for drain pump failure
Check that the inlet valve shuts off fully
Check that the pressure switch is operational.
Posted on Apr 06, 2011
sodeep
  • 3267 Answers
SOURCE: reset error code F08 in
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Posted on May 28, 2011
Washing machine.. Whirlpool red service light has come on and fault flashing is f08. Any one experienced this or knows what I'm in for?
You need to give your Model number to get the exact codes for your machine. Google the machine name with the model number and "washing machine codes" at the end and look at the resulting websites.
Jan 02, 2013 | Washing Machines
Getting f08 error on my hotpoint wf740p
Call Hot point and ask them what an f08 error is, or check the booklet that came with your washer-they usually have a list of common errors.
Nov 22, 2012 | Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Good luck,
John C
Mar 09, 2011 | Washing Machines
I have an F08 Code flashing on LCD display,
F08 Heater relay cannot be activated
You need to contact service technician to solve this problem.
thank You
Sep 12, 2010 | Hotpoint Washing Machines
My hotpoint is showing error f08
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
Sir, I hope this helps.
Sep 17, 2009 | Washing Machines
Hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hot point washing machine has a symbolF-08)
F08 means heater relay cannot be activated..
Usual cause is faulty heater.
If you are able check the heater for continuity or an earth fault, then you will need a meter to do so.
If the heater and thermistor check out o/k, then you are probably going to have to call an engineer..
Please leave feedback.
Dec 07, 2008 | Hotpoint Washing Machines
Hotpoint washing machine WF860 F-08 error, does anyone know how to fix this
hope this helps
Sep 29, 2008 | Hotpoint Washing Machines
Open Questions:
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
