SOURCE: PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
SOURCE: thermador oven secd272bs error code after install
check your owners manuel for code meaning and how to clear if its new call for service some can push stop reset or clear
SOURCE: KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Testimonial: "worked, thanks"
SOURCE: Getting error code F10 on Kenmore model 47889603 wall oven
Leaving the breaker off for the time I was at work (about 9 hours) seems to have cleared the problem. May have just been an abberation and not an actual problem with the appliance. Since the first step with most electronics that develop a fault of some type is to power down for a while then power back up to reset the electronics, I decided to see if that would do it and it did. Thanks for having a site to go to for assistance, though!!!! -Mike-
SOURCE: I have RBD305PDS14 double oven. Touch pad (front
there should be a 40 amp breaker in your electrical panel turn off and back on again to reset power
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
