SOURCE: Funai 13" TV with VCR Combo
You can check the remote by holding it very near an AM radio. Have the radio turned on and tuned about the middle of the AM broadcast band and push the button on your remote. You should hear a popping sound come through your radio speaker. If you can't hear anything, try moving the remote around and tuning the radio. If all fails then the remote is not working. If you DO hear the popping sounds then you have a problem with the IR receiver in you TV. There's a little plastic "window" in the front of your set where the IR signal enters. If dust has collected on the inside this could block the IR signals from entering. Also the IR receiver itself may have gone bad. The remote for this TV has to be an exact replacement. I've had this problem too by trying a substitute. Stargazer
SOURCE: remote
if the remote works then why are you posting in here? for the cable remote? I would bet the ir signal board in the tv is not connected to the main board or it is bad. return the tv for an exchange
SOURCE: keyless entry remote quit working. Just purchased
Transmitter Programming
Notes
SOURCE: Have an RCA Univeral remote RCR311 need code for a GPX TD4022 HDTV
go to www. fitness.manualsonline.com or www.remotecodelist.com
God bless you.
SOURCE: CODE NUMBER FOR GPX TD4022 HDTV TO VERIZON FIOS REMOTE
You can usually call the manufacturer of the remote & they will give you the code needed.
Testimonial: "No code for the model i bought yet,in the future."
