Question about Lanier Office Equipment & Supplies
Lanier LW326 Came on then shut off you could make me a hero if I find out why. Are there fuses I cant find?
Lanier printer spc240dn engine menu nsequence
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Apr 01, 2015 | Lanier Office Equipment & Supplies
Why does the Lanier get stuck and can't start the machine.
Hi Theresa,
Have you tried cleaning the lanier? wipe it down lightly with a cotton swab, and check to see if there is light lubrication on the rail.
Normally over time the light grease tends to get sticky and causes the same problem. 3 -1 machine oil would work as well.
Hope it helps
Sep 28, 2014 | Office Equipment & Supplies
Lanier MP C2500 SC561
That is from a dirty thermistor in the fusing unit. It is the one touching the pressure roller.
Jun 10, 2014 | Lanier Office Equipment & Supplies
Sc542 error on lanier
That is a dirty thermistor in the fusing unit.
Apr 14, 2014 | Lanier 2045 2145 5635 5645 Toner 23 000...
Lanier 6514 copier, copies are coming out all black....
exposure lamp open circuit replace or lamp regulator faulty also check thermo fuse 1st thing to check change auto exposure to manual this will tell you if regulator is faulty or not
Oct 21, 2010 | Lanier 1205 Copier
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
LANIER COLOR COPIER MODEL LD345c Funtional Problem SC541
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Apr 07, 2010 | Lanier 1205 Copier
My htc hero keeps shutting off and turning back on. I cant get it to stay on.
my htc tattoo is doing the same, i read that you should try taking out the battery for a while and then putting it back in, if that does'nt work you may need to buy a new battery, just taken my battery out dont know if this is any good, just thought id mention it for you to try
Feb 17, 2010 | HTC Hero Smartphone
18 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
