Setup Of The Device
When you see Roku error code 009 it simply means your device has successfully established with the router but not get connected with the Internet and Wi-Fi that means your device is not recognizing the Wireless signal for your network and start displaying error message as "Unable to connect to wireless Network" or "Roku error code 009".To fix this issue follow this steps--
Change the Modem's DNS Configuration Settings:
Once you are going to check the settings, you need to amend the configuration of DNS. after you are done with updating the firmware, make sure that you're adjusting the ACL/MAC address filtering. The moment you are done with that, there is a need to adjust the security mode and modify then modify the DNS servers.
This might be the reason why you are facing the Roku 009 error code. If you are not able to fix it with this step, then you can try the next step.
Wrong Activation Code:
Well, one of the common causes that you are going to see that is responsible for the issue is entering the incorrect activation code. At the time of activating the Roku, there is a code that is provided to us and that is called as the activation code.
So it is recommended that when you are entering the Roku activation code , make sure that you are entering the correct code without any error.
If you look at the Roku Error Code 009, the device has successfully connected to the router, but cannot access the internet. This is also similar to Error Code 14. In essence, your device does not recognize the wireless signal for your preferred network and displays error messages such as "Unable to connect to the wireless network" or even the message "Not connected to the Internet." Solution : https://www.errorcodeexpert.com/how-to-fix-roku-error-code-009/
SOURCE: my dell 3110cn printer is
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
