Approx manufacturers date is 1885 - 1890
drop these folks a line.
https://www.wwgreener.com/historical-guns.html
SOURCE: Can you tell the age of a shotgun by the serial
Some shotguns don't even have serial numbers, Make and model will tell more than a serial number unless it is a very rare piece. Is it an old Belgian Browning auto 5?? Something like that , you can tell.
SOURCE: browning shotgun sweet sixteen age and value
In general, a 1950s Sweet Sixteen is a valuable gun. Measure the distance from the trigger
to the end of the **** stock to get the "legnth of pull" (LOP). this
was 14 1/14 " when it left the factory. If it is shorter, the value
will be less.
Without seeing it, although many have been altered which would bring a price $350 - $450 area.
This guide might help if you can determine the condition : OS is 1958.
AUTO-5 SWEET 16
- 16 ga., 2 9/16 in. chamber from 1937-1940, and 2 3/4 in. chamber from
1947-1975, similar configuration to Lightweight, 12 and 20 ga., gold
plated trigger, 10 oz. lighter than Standardweight Model 16 ga.,
1937-1940 mfg. Sweet Sixteens were available in pre-war Grades I, III,
and IV. Mfg. 1937-1975 by F.N.
Grading ...............98% ....95% ....90% ........80% ........70%
Plain Barrel .......$950 ...$825 .......$725...... $625 .......$500
Solid Matte Rib $1,300 .$1,075 ....$950 .......$825 .......$700
Vent. Rib .........$2,100 .$1,650 .....$1,225 ...$1,050 ....$875
Subtract 20% for front safety.
Subtract 20% for 2 9/16 in. chamber.
SOURCE: I am requesting the value
May I get the make and serial # to help you more. You forgot to put that info in your question.
SOURCE: How can I tell the age and serial number of my Springfield 947D single shot 12 guage shotgun
Frank, See if you can find a date code on it somewhere.
It's a small oval with a number and a letter stamped inside of it.
You can also google search with what you do know about gun, lots of info out there. check the link, good luck.
Springfield 947D single shot 12 gauge shotgun serial number location...
