Question about Navman GPS
I have a Navman GPS which has developed a white mark on the screen where I touch the screen with my finger.
Is there I way I can get rid of the white mark.
5 Suggested Answers
SOURCE:
  • 32 Answers
SOURCE: navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
Posted on Jun 01, 2009
mattofilms
  • 110 Answers
SOURCE: My GPS just stopped responding to touch.
can you soft or hard re-boot your GPS?
(usually by holding down the down button + menu)
Posted on Jul 02, 2009
  • 1111 Answers
SOURCE: the display stopped working on my Magellan maestro 3100
sounds like you need another screen, but without looking at these spots i would try an update first
Posted on Jul 08, 2009
SOURCE: I purchased a NAVMAN S-150
I have the same problem, the s150 touch screen is pathetic, Got the same story from Strathfield Car Radio..it was normal and had it in for repairs twice when the screen went crazy with vertical lines, same fault both times. I went back to using my s50 and will sell the s150, it is a highly complex, very pretty lemon. They wont refund you or give map upgrades for inconvenience caused by their faulty product. To sum the s150 up. A truly Miserable experience. Rate it out of ten? its a minus.
Graeme
Posted on Mar 13, 2010
Reset with no disc etc
SAT NAV - RESET PROCEDURES FOR GARMIN, NAVMAN, TOM TOM
Updated 08/05/2014 05.01 PM
Reset Procedures for Garmin, Navman, Tom Tom
Garmin Master Reset NB: This will erase all way points or favourites and will restore your unit to the default factory settings.
NuviĀ® 2xx, 2x5, 5xx, 6xx, or 7xx.
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON.
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touch screen when this message displays.
  7. Touch Yes.
The device will automatically reset. Please follow the on-screen prompts on the n?vi and when completed, place your device in an area with a clear view of the sky until it acquires satellites.
NuviĀ® 8xx or 5000.
  1. Turn the device OFF (you will need to remove the battery from a nuvi 8xx).
  2. Turn the device back ON (you will need to install the battery into the nuvi 8xx).
  3. When you see a progress bar on the screen of the unit, quickly place your fingertip, or the eraser end of a pencil, in the bottom right corner of the touch screen.
  4. Hold the bottom right corner of the touch screen until a message says, "Do you really want to erase all user data?"
  5. Release the touch screen and touch Yes.
  6. The unit will now restart.
  7. Follow the onscreen prompts to set up the nuvi.
Navman S30/50/70/S80/90i.
  1. To reset your device, hold down the power button for at least 10 seconds and the device will power off.
  2. Press and hold the power button to turn the device back on.
For other models, please visit this link, select model and search for 'reset'.
TomTom
  1. Soft reset - select your model.
  2. Reinstall TomTom application.
  3. Format internal memory or memory card.
Apr 01, 2015 | Navman S30 3D Portable GPS Automobile...
I have a cracked touch screen My &%T can it be
Welcome to FixYa!
Yes it ca be replaced. Go to Satellite Navigation Repairs for qoutation. Click the link below. http://satnavrepairservice.com/repair-satnav/navman-repair/14.html
Thank you for using FixYa. Have a great day.
Jas247
May 10, 2011 | Navman Navm ICN630 GPS Receiver
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
I get no response when i push i agree on first screen
Then you have to calibrate the screen since it is not responding to touch. To calibrate the screen, follow the steps below:
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Jan 02, 2011 | Garmin nuvi 255W GPS Receiver
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
Mi navman my55 wont turn on unless it is connected to the car power supply it is reading the batt is full and wont turn on even if connected to computer or power plug
my navman 55 has developed a problem it will not arrow down on any screen and the touch screen has been hard to operate from new
Aug 04, 2010 | GPS
Garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Apr 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
I purchased a NAVMAN S-150 GPS In-Car Unit last week from ****-smith online shop. I have been testing this device for several days now. Why is it that the various touch screen buttons respond differently...
Graeme
Nov 21, 2008 | GPS
Touch screen not responding when using stylus.
Is it just possible you left the Navman mounted on the screen in hot weather whilst away from the vehicle? I made a little white jacket for mine with a heat reflecting liner.
Nov 17, 2007 | Navman ICN510 GPS Receiver
GPS Logo
41 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
