SOURCE: child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
SOURCE: Samsung 40" LCD HDTV #LNS4041DX/X
I the same problem and I found that the Capacitors used on the power supply portion of the circuit board were leaking and/or bulging. These parts were failing and as a result the problem worsened with time. If you are able to remove and solder new parts on to the circuit board follow the following procedures. Or get a technician to do the repairs.
1) Make note of connections at back of TV.
2) Unplug power cord and other connectors from back of TV.
3) Remove back of TV with a Phillips (+) star shaped screw driver.
4) Note the position of all connections to the main board.
5) Remove circuit board taking care not to damage any of the components.
6) Locate parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors.
7) Remove and replace parts with capacitors of equal physical size that are (1000 uf ). I would recommend a voltage rating of 25v or 32v. Note that the voltage refers to the amount of voltage the capacitor can handle. The higher the better.
8) Reinstall and reconnect the circuit board.
9) Replace back on TV and setup the unit as before and you’re done.
10) Enjoy!
I replaced the parts for just under $10.00.
SOURCE: need additional remote codes for emerson tv - codes listed on
Hi if you haven't already, try these codes: -
000, 127 or 141
SOURCE: Set TV Code for Yamaha Remote RAV-290
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
SOURCE: craftsman 1/2 hp screwdrive, model 139.53927 works
The wall control is hard wired and doesn't use the receiver in the logic board which the remotes do. You most likely have a bad logic board.
