Question about Measuring Tools & Sensors
My acurite model 01046/02081 reads the outside temperature higher then it is and the forcast is off on it. It has new batteries and is placed less then 300 feet from station outside
    Top Expert:
  • Measuring To... Master
  • 54,195 Answers
The outside sensor is in the sun.
Posted on Feb 26, 2019
SOURCE:
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
VtToolMan
  • 704 Answers
SOURCE: outdoor device won't register inside.
All these wireless weather station devices have to be paired to the base unit whenever the batteries are changed in any of the remotes. It's a poor design issue, but there is no way around it, due to the nature of wireless operation.
Place both units near each other and look on the back of your base and remote sensor units, you should find a reset button (or a small hole). Either press the button or use the end of a paper clip to depress and hold the reset on each unit; Base 1st, then the remote 2nd.
After a brief moment, the remote should register with the base and you'll be back getting wireless readings.
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
Testimonial: "The back of the central until says CH and the remote says TX. As you say, not very helpful."
bschilz
  • 2049 Answers
SOURCE: the message center shows incorrect outdoor
I would suspect that the connection to the outside temperature sensor is not good or the sensor itself is bad. Check the connection and clean and reattach as necessary. Otherwise replace the sensor. I think they're pretty reasonably priced.
The outside air temperature sensor for a 2000 Windstar is located under the front bumber on the passengers side. It is clearly visible if you lay down and look through the lower two air openings in the plastic bumper. It is the only electrical device in that area and it is made of black plastic.
Posted on Sep 22, 2009
SOURCE: 2004, FORD EXPLORER, OUTSIDE AIR TEMPERATURE
the sensor is located inside the air intake tube
Posted on Oct 23, 2009
SOURCE: acurite 1097-rx will not display outside temp or
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
Posted on May 11, 2010
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Oct 02, 2018 | Acu-Rite Acurite Wireless Weather...
New owner of AcuRite Model 75075. Outdoor temp (just now installed) is reading 7 degrees higher than actual tempperature. How lond does it take for the indoor & outdoor unit to get in Synch?
Typically the Sensors Sync-Up within 10 to 20 Minutes. However, placement of the Outdoor Sensor is also important. The National Weather Service (NWS) and NOAA measure the Temperature in the Shade, and NOT in the Sun. So be sure that your "Exterior Sensor" is placed in the Shade, under an overhang for example. However, be careful not to place the sensor under an overhang, where there may be a soffit-vent or gable-vent, that is used to vent out warm air from the attic. Even a three (3) season, unheated porch can be warmer than the actual external temperature, due to passive/solar heat captured thru the windows (East/South/West).
Jun 08, 2017 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Measuring Tools & Sensors Logo
127 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
