How to remove SIM card from lg b470 model
I think this will explain the process for you:
https://www.att.com/devicehowto/tutorial.html#!/stepbystep/id/stepbystep_KM1274305?make=Apple&model=iPhone88Plus&gsi=NYJI138E
SOURCE: SIM Card
You should be able to find it once you remove the battery from the mobile. Here is a pic:
Sometimetime it will be located inside a slot or by a cover, depending upon your model..
SOURCE: how do i remove sim card from iphone a1303
if you have your sim tool (safety pin like) stand cell up right..on the top you'll see a hole ..insert tool sim tray should pop up..place sim card on to tray, place tray back into cell...start txtg & chattin
feel free to rate help
SOURCE: how do you remove sim card from a samsung knack?
This phone is CDMA, so it does not have any sim card slot as it has inbuilt system which is directly operated by the service provider.
No other service provider is compatible with this phone.
Good luck
Testimonial: "Thanks, now I can just forget this problem."
SOURCE: How do I remove the sim card from my Lg 5500 cell
The LG vx5500 does not have a spot for a SIM card or memory card
Power off your cell phone.
Remove the back battery plate. Depending on the make and model of the cell phone, you will either have to slide the panel off by applying pressure with your thumb or by sliding a small latch and then removing the plate.
Take out the battery.
Look for the SIM card door. It will be shiny, silver and will be clearly marked. You'll also be able to see your SIM card.
Open your SIM card door by sliding it open (follow the arrow directions on the door) and sliding out your SIM card.
