SOURCE: I need to replace the drum roller in my 21 year old Kenmore dryer
My husband after numerous tries,(while his mind was on March Madness and several trips to the den to keep up with the game) was able to get it off for me after the game was over. I have ordered the part and am now waiting on it to arrive. Thanks so much for being there for us. It is a relief to know where I can find help next time I need something.
Sandra
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
SOURCE: delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
SOURCE: NEED MANUAL FOR 31-250 DELTA DRUM SANDER
here is the parts list with exploded view:
http://www.ereplacementparts.com/delta-31250-type-drum-sander-parts-c-3275_3512_3539.html
and here is the owners manual:
http://www.redmond-machinery.com/Manuals/Delta/Delta%2031-250%20-%20OM.pdf
Bob
