Refrigerators Logo
A
Anonymous Posted on Feb 25, 2019
My haier stainless steel fridge freezer is scratched, anything I can do to minimise them?
Stephen Miller
Level 3:
  • Haier Master 1,645 Answers
  • Posted on Feb 25, 2019
Stephen Miller
Haier Master
Level 3:
Answers
1645
Questions
0
Helped
864992
Points
9471
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Nov 06, 2007
SOURCE: stainless steel refrigerator with a bad scratch
Check out this site and see if it helps. Usually stainless has to be buffed out. http://www.stretcher.com/stories/01/010723a.cfm
dcp2
Daniel Phillips
  • 63 Answers
  • Posted on Jan 28, 2008
SOURCE: Haier 4.6 stainless steel fridge...
Check the thermostat. make sure it is turned on. The thermostat can shut it off. Also check to see if you have power to that outlet you are using. If none of that is the problem you can try and bypass the thermostat with a jumper wire( If you are comfortable with do this) Be careful when doing this cause electric shock is possible. don't touch any wires directly
Anonymous
  • 66 Answers
  • Posted on Feb 07, 2008
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Anonymous
  • 218 Answers
  • Posted on Jul 25, 2008
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Anonymous
  • Posted on Sep 29, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
I have a 3.3 fridge/freezer-the back wall of the fridge has a buildup of ice ???
Sounds like either: 1) The thermostat is set too low.
2) The defrost control is bad
3) The main drain in the freezer has frozen over not allowing water to drain.
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
1helpful
3answers
My houselady cleaned my fridge today with a stainless steel cleaner and now it looks like there is a blue residue on my fridge that will not come off. Is it ruined?
I am not exactly sure how to remedy your specific issue but I know of a site that sells decorative covers for your appliances. Check them out at www.applianceart.com These guys have covers for all occasions and even stainless steel. Hope this helps.
How do you get fine scratches of the stainless steel door?
Firstly remove the handle, find the "allen" screws at underside of handle ends. Start first with a coarse towel and "re-scratch" the area. If that was not enough becoming more aggressive, use much care/ gentle pressure- a 3m scotch brite #7447 "going with the grain", you in essence are removing those scratches with scratches. Use DeBruce Polish with the grain for rourine cleaning and touch-ups. We use DeBruce Polish on all of our stainless steel. Non-toxic, non-abrasive and odorless, DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
2answers
Stainless steel finish on Liebherr fridge
if you have scratched or damaged the surface, you can get a stainless steel foil product to cover your refrigerator from www.applianceart.com. If its not that bad, make sure you are using a stainless steel cleaner after you have washed it with a regular cleaner.
3answers
SCRATCHED STAINLESS STEEL SINK
Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
