It is 1 year old and worked fine until recently. The solar panel is in bright sun and suddenly gets very dim or doesn't come on at all???
SOURCE: Dim LED Lights
We can replace the VFD tube for you. The total cost for this repair is $71.06. For more information, our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
SOURCE: only brights work, dimly lit headlamps, no fog lamps
Recheck the bulb number. This happens when the wrong bulb number is installed. Otherwise it could be a bad headlight ground.
SOURCE: instrument panel lights don't work
please advice, have you solved the problem? I have the same one on my Sebring. Many thanks.
