The dogs at rest are a bit to high to slide fabric into the sewing position.
Just as a test try selecting a straight stitch and short stitch length. Then advance hand wheel a couple turns leaving needle at the highest position. If feed dogs remain higher than needle plate, power machine off wait a few seconds, power on. It should power up to a straight stitch with nominal width and length. Rotate handw heel if necessary for needle maximum up. If dogs are still higher than needle plate... not sure. Comment below and I'll search for model specific issue.
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
SOURCE: Feed dogs
It probably needs gears replaced or has a loose gear. Unfortunately you need to take it in to a repair shop. (I am assuming that you are not in button hole or have the stitch length set to zero).
good luck!
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
SOURCE: Brother XL-6562 sewing machine is not feeding fabric through properly
Oil might help but it sounds like you don't have enough pressure on the foot. You can take the casing off where the light is and there is a screw back there that controls the tension on the pressure foot. It is not meant to be changed by anyone but a professional. I've changed the tension but it wasn't easy. If you are still interested let me know and I will try to explain.
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
