SOURCE: Changing program source without remote
Do a web search for a replacement remote control. If you got the tv without a remote, then I'm guessing you don't have a manual either. Here's a link to a free downloadable manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e341b6ad1733d53ba32cb47caf24d013&q=Sanyo+DS19330
SOURCE: I have a White Westinghouse TV model WTV 11901. I
look at the back or side of your television
SOURCE: White Westinghouse Model No WTV 11901 television
It sounds like your TV is not equipped with audio/video (A/V) jacks. Many older TVs don't have these. You need to get an RF modulator that will convert the A/V output of the DVD player into a Coaxial cable that you can plug into the back of your TV. I'm including a link to one at Radio-Shack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel. I hope this helps you out.
http://www.radioshack.com/product/index.jsp?productId=2103095
SOURCE: Can we get to imput without remote?
Remotes are cheap (I got one for my TV for $4). Getting a remote is the best solution
SOURCE: how to get to menu without remote
you can only get the menu without remote, if the menu button is at the front of the television but if otherwise you can can get a all in 1 remote control for to get the menu of the television .
Thanks for asking...
