Specifically for the AC to DC charger adapter, lamp bulb and battery.
Adapter.
UpBright AC/DC Adapter Compatible with Vector VEC1138 ...
https://www.amazon.com > UpBright-Global-Adapter-V...
BatteryGuy Vector Sport SPOT 138BY Replacement 6V 4.5Ah Battery ... VEC139 VEC139C Xtreme Sport Spot Rechargeable Spotlight VEC192 VEC193 VEC189 Power On ...
Power Source: Corded Electric
Output Voltage: 12 Volts
Battery
Vector SPORT SPOT 138BY replacement battery ...
https://batteryguy.com > vector+sport+spot+138by-repl...
The 6v 4.5Ah Rechargeable Sealed Lead Acid (Rechargeable SLA) Battery ' BG-645F1 is a premium alternative to the Vector SPORT SPOT 138BY replacement battery ( ...
US$5.76 · In stock
The bulb is a halogen car bulb. Take it to your local auto parts store like Canadian Tire.
SOURCE: Need adapter for Vector 1 Million sport spotlight Model VEC156
if its the one im thinking of, i had the same problem.
if you look at the back and theres the male prongs to plug into the wall
well what i did was i took off the back
then i took off the cradle that held the battery in place, and stood it up on the lens and simply plugged it into the wall to charge it.
its kind of complicated but simple way to save some dough in todays market.
SOURCE: Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Testimonial: "Thank you so much!! I do appreciate it!"
SOURCE: looking for replacement parts for vector spot light
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
SOURCE: Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Testimonial: "Thanks RetiredRon, this was the first post I'd seen for the polarity of the plug."
