It won't start
I appreciate your post, Aeraci Los Fresnos!
From the information you have provided your Frigidaire dryer is providing an error code of "E63". The "E63" code stands for heater to earth has been grounded, this could be a possible issue with your heating coil or connector. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes this will help clear out any miscommunications. If you continue to experience an issue with the "E63" error code I would suggest consulting with a professional technician come out and provide an accurate diagnosis for repairs. Best of luck! -OOS
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
