Http://www.fixya.com/support/t16038566-heater_fan_electric_fireplace_not
SOLVED: We have an electric fireplace - the blower fan is - Fixya
www.fixya.com/support/t8228181-electric_fireplace
1 answer
Feb 10, 2011 - Don't despair, it's very common with electric fireplace/heaters. ... If that didn't solve your problem, either the fan motor is bad or the switch to turn ...Missing: Alcove Auburn
SOURCE: Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: Charmglow fireplace, everything on, no heat
its either a sensor or the element most times sensor or limit.
SOURCE: Light and flame work, but
Chances are you have a bad thermal in there. It is almost always on top over the coils. They usually go if the fan motor is soon going to quit or the air intake is dusty. Check the motor before replacing it, It should still work without heat on. Only change the thermal with the same temp rating !
SOURCE: Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
