Frame is in the way of taking it off
SOURCE: where and how to change cabin filter chevy equinox
Hiya...the cabin air filter is located below the front passenger/windshield area.
It's only accessible by standing outside the Equinox with the hood open.
Here's how to do it...(before you pop open the hood)
1) Stand outside at the front-right door area.
2) Just below the front windshield area, pull up a few small black plastic clips that's on the black windshield wiper cowl area- a small flat screwdriver or a special clip-remover tool is handy.
3) Raise the hood up.
4) There may be a triangular-shaped hard foam sound damper at the left side nearby the hood hinge...pull it off if it allow you to work around it with ease.
5) Continue to find a few black plastic clips around the black windshield wiper cowl area.
6) Gently pull up the black windshield wiper cowl cover with care not to bend it too hard during removal.
7) You should see the cabin air filter inside that's held in place by a black rectangular box inside.
8) There's 2 black tabs that holds the cabin air filter in place.
9) Insert your finger or tool to pry the cabin air filter away from the tabs.
10) Remove old cabin air filter.
Remember to reinstall the clip parts back into place when you're finished.
SOURCE: need to change oil pan
e
Cavalier, Sunfire 2001-2005
Oil Pan - Removal & Installation
2.2L (VIN 4) Engine
To install:
Negative battery cable
Right front wheel
Right inner fender splash shield
Starter motor and bracket
Engine mount strut bracket
Oil pan
Fig. Exploded view of the oil pan mounting and related components-2.2L (VIN 4) engine
2.2L (VIN F) Engine
Oil pan with a new gasket. Torque the nuts and bolts to 89 inch lbs. (10 Nm).
Engine mount strut bracket. Torque the bolts to 49 ft. lbs. (66 Nm).
Starter motor and bracket. Torque the bolts to 37 ft. lbs. (50 Nm).
Right fender splash shield
Right front wheel. Torque the nuts to 100 ft. lbs. (140 Nm).
To install:
Drive belt
Lower then upper AC compressor bolts
Oil pan bolts
Oil pan
Fig. Remove/Install the oil pan bolts in this sequence-2.2L (VIN F) engine
Oil pan and tighten the bolts to 18 ft. lbs. (25 Nm)
AC compressor bolts
Engine mount bracket
Drive belt
2.4L Engine
To install:
Flywheel/converter cover
Right wheel
Right wheel well splash shield
Accessory drive belt
Air conditioning compressor lower bolts
Transmission-to-engine brace
Radiator outlet pipe bolts
Radiator outlet pipe from the oil pan
Oil pan to the flywheel cover bolt and nut
Flywheel cover stud for clearance
Radiator outlet pipe from the lower radiator hose and oil pan
Oil level sensor connector
Oil pan
Oil pan with the gasket. Torque the M8 bolts to 18 ft. lbs. (24 Nm) and the M6 bolts to 106 inch lbs. (12 Nm).
Fig. Oil pan fastener torque specifications-2.4L engine
Oil pan to the transmission nut
Radiator outlet pipe to the lower radiator hose and oil pan
Exhaust manifold brace
Radiator outlet pipe. Torque the bolts to 124 inch lbs. (14 Nm).
Engine mount strut bracket. Torque the bolts to 55 ft. lbs. (75 Nm).
Transmission to the engine brace
Air conditioning compressor lower bolts. Torque the bolts to 37 ft. lbs. (50 Nm).
Right splash shield
Right front wheel
Hope helped (remember rated this help). Good luck.
SOURCE: 2005 chevy equinox rear hatch not locking
I've had the exact opposite issue with my 2005 Equinox.
My rear door is locked and will not unlock.
SOURCE: reset engine oil change light
turn the ignition on and press the gas pedel three time and the oil light will blink and the go off the then the system will be reset
SOURCE: 2005 Chevy Equinox, LT
at 60k, if it aint been done,do the lot.....filters oils.....antifreeze.....belts.....timing belt. then you have another 60k before you have another big bill.....
Testimonial: "Thanks for the help. I didn't realize that it would need a timing belt so soon."
