Freezers Logo
Paul Bateup Posted on Feb 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer alarm on and not working
Red alarm light on, freezer has defrosted, stays cool, but not freezing
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Feb 25, 2019
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020063
Points
74913
Most likely sealed system blockage or leak
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on May 19, 2006
SOURCE: Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
Anonymous
  • 473 Answers
  • Posted on Oct 07, 2007
SOURCE: whirlpool 10cube chest freezer red light
yes.
Anonymous
  • 7 Answers
  • Posted on Jan 17, 2008
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Anonymous
  • 417 Answers
  • Posted on Feb 16, 2008
SOURCE: Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
douglas smith
  • 1462 Answers
  • Posted on Oct 20, 2008
SOURCE: warning alarm and light
it will do that till temp is reached
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
The temp on my freezer is on normal and was working ok then just stopped and the red light is on turned up the temp to make it colder and the fast freeze but not working and everything is defrosting
Hi Denise, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
2answers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
1helpful
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
1helpful
Alarm
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
