Http://www.fixya.com/support/t24326835-repair_front_left_wheel_height
Jul 21, 2017 - The wheels are held on by a screw behind the wheel guard, i suspect your heightadjuster has come loose off the spline, this can ... Best thing about this new service is that you arenever placed on hold and get to talk to real repairmen .... my royal 4000 height adjuster-slips and dose not maintain set height.
Vax problems Why is the vacuum blowing out the ...
May 17, 2014
SOLVED: My shark cordless vac won't hold a charge
1 answer
Apr 7, 2012
SOLVED: My vax vacuum has started making a ...
Feb 7, 2012
SOLVED: Sebo upright vacuum cleaner - Bag full ...
Jun 17, 2010
More results from www.fixya.com
SOURCE: Rear air ride suspension is not maintaining height
The are ride height adjusters the look like arms. they are mounted on the bottom of the struts and lower control arms that control the height The can be adjust but for the most part if the were working fine before then they need to be replaced. Make sure that there are no leaks in the system.
SOURCE: foot pedal not working
sounda like the rachect teeth inside peddle r worn out probably need to take to shop for repair
SOURCE: The grind and dose controls are slipping. They are
You will have to remove the bean hopper,realign the grinder,then refit the bean hopper
SOURCE: Clutch is slipping is there an adjustment? 1997 royal star
Yamaha has a curved washer style clutch spring that it uses for this model. These have been prone to slipping from day 1. Normally when you get on the throttle hot and heavy. A new spring will help the situation for a while but you may have to replace the clutch pack to get more pressure through out the clutch pack if the bike has high miles on it. Maybe the dealer would know if the VMAX spring is heavier and would work as a replacement.
SOURCE: Poulan pro front wheel drive
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
