see this causes and fix it. God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to
corner) check the leveling legs. Make sure to tighten up the locknut
after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest
replacing the timer
as soon as the noise develops. This can cause problems with your motor
and other components if left alone. This is easy to identify just listen
up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct
drive remove the motor and rotate the inner tub and listen for noises it
should be quiet. If not the transmission is expensive and you will need
to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To
check and replace the motor coupler watch the video.
Motor
You will need to
disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models
check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The
washer must be disassembled
to access. These usually do not fail. On direct drive types there will
be springs instead of suspension rods. Either usually fails but can from
being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the
belt and rotate the pump pulley it should spin freely and make no
noise. If it is noisy replace. If it does not spin freely remove and
inspect for obstructions if none found replace the pump. Check the
impeller on the pump it should be tight and spin freely. On direct drive
types
remove the pump and inspect or replace.
