I would refer you to the Lexmark manual for setting up the scan-to-pdf function:
http://support.lexmark.com/index?pmv=print&page=content&locale=EN&userlocale=EN_CA&id=SO5227
SOURCE: How to can multiple pages into one pdf file using Lexmark x4530
Open Acrobat. Under "File", click "Create PDF" then "From Multiple Files"
Remember to rate :)
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
SOURCE: MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
SOURCE: can't scan to PDF
I would suggest scanning each page into their own file, convert each into a .pdf, and then using a free program to combine the .pdf pages.
Search download.com
SOURCE: Konica Minolta bizhub 750 scan file type default settings PDF
Once you have selected PDF on the screen touch you Ulitly/Counter button, then select User settings, display settings, Scan Basic default.
can go to konicaminolta us web site and down load a operators manual for scan, copy, fax etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
