Question about Refrigerators
Hi there i have water uner my crispers i have clean out top of freezer behind paNEL and it is still leaking
  • Deb wirsching
    Deb wirsching Feb 24, 2019
    I am having trouble finding the location of this tube looked at back of refrigerated and back of freezer any guidance you can give me
  • Chris Huff
    Chris Huff Feb 24, 2019
    In freezer section behind back removable wall panel. Under evaporator coils.
    Top Expert:
  • Refrigerators Master
  • 6,278 Answers
Defrost drain probably clogged
Posted on Feb 24, 2019
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
SOURCE: Water leaking from freezer down back wall inside fridge
I have a GE Profile Perfomance Model 22 ( TN22PRCBRBS)..I`ve had it for 11 years and I`ve noticed a leak developing from my ice maker onto the base of the freezer..I`ve had to chisel the ice that continously forms everyother day..I checked to see if I could investigate but I can`t get to the source ,which is the water line connecting to the ice maker itself..Any suggestions?
Posted on Jun 18, 2008
SOURCE: Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Posted on Jun 26, 2008
  • 148 Answers
SOURCE: water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Posted on Jul 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: I have water (condensation?) leaking from under the freezer
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
WHY IS THERE WATER LEAKING INSIDE THE REFRIGERATOR
generally water leaks on top mount freezer types when the defrost tube is plugged. The automatic defrost system works to keep humidity from blocking air flow across the evaporator(behind the back freezer panel) If it can not drain you will see it as water dripping from the top of the fridge section and water under the crispers.......Clean the drain tube under the evaporator of ice(poke a hole in evaporator and you are buying a fridge)........hope this helps
Jul 29, 2012 | KitchenAid Refrigerators
My ETFTKXKQO fridge has been leaking inside frige, into crispers and glass shelves, I cleaned it our today and unplugged it hoping to thaw out blockage. I do not have an ice maker. There was no water in...
Drain for the defrost is between the walls of the refrigerator. By removing the back panel in the freezer you can see the hole in the drain trough. The disk you see behind crisper is for air return.
Dec 07, 2010 | Frigidaire Refrigerators
Leaking water into crisper. Water is freezing in freezer pan. Model 21TFA.
i would say you have a pluged drain tube from the top locted behind the freezer rear panel.
Nov 27, 2010 | Whirlpool Refrigerators
Water is accumulating under the crispers. Will be and inch deep.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 25, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
GE tfx22r leaks water out bottom of freezer door. Bottom of freezer covered with ice. Vacuumed and cleaned evaporator and coils. ice maker water is shutoff. Water seems to be coming out from behind crisper...
defrost drain is clogged, remove back panel, and pour hot water down drain and blow it out with pressure of some sort until water passes freely
Nov 01, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
