SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
and?
