Question about Watches
How we set date and alarm in takane AD42C wathch?
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
See Steps below:
*Setting the time*
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
Instructions for Armitron All Sport 40/6623 time setting needed.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
Apr 02, 2011 | Armitron Digital Sport 406623BLK Watch
Instructions for setting time & date of armitron watch 44/1001?
Nov 08, 2010 | Watches
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Watches Logo
52 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
