SOURCE: Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
SOURCE: Plays for 3 secs, stops, and then ejects
This unit needs to have the "idler" changed as well as the belts. Over time, the internal rubber parts get hard ans slippery. There are safety checks inside that will stop the unit when problems are detected. With a slipppery idler assembly, the tape does not get wound into the cassette after passing the heads. Rather than have the tape collect inside and be destroyed, the unit stops. This is a relatively simple repair that any shop should be able to perform. Expect a parts cost in the $35 range. In my opinion, this unit is worth the repair as it will continue to provide service to you for years to come. New replacement units tend to last only a year or two.
Dan
SOURCE: need remote code for mitsubishi vcr
Need remote control for Mitsubishi HS-820V(IR) VHS recorder,any idea where I might get one
Regards
Vincent
