This website is a joke. Just links to related brands but not specific to the question. Ads ads and more ads...
as always just figure things out the trial and error way and be done with this joke of a source of ad revenue..
www.fixya.com/support/t26761670-disable_alert_beeping_cuisinart_coffee
Oct 5, 2017 - Hi there, Save hours of searching online or wasting money on unnecessary repairs by talking to a 6YA Expert who can help you resolve this ...
Is there a way to turn off the beeping of the Cuisinart
Feb 23, 2019
How do I disable beep on Cuisinart DCC-1100 ...
1 answer
Apr 4, 2018
I have a cuisinart ss15 coffeemaker. The clean light ...
1 answer
Apr 4, 2018
SOLVED: Cuisinart coffee center, ss-15, lights are
1 answer
Feb 13, 2017
More results from www.fixya.com
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar
with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of
the unit and in one of the corners you should find a filter stick or
column that is removable. Pull it out and open it up to clean out the
clogged up carbon filter in there. (You can later buy a new filter on
Amazon.) Clean out the debris from the bottom of the cavity. Replace
the stick into the cavity once cleaned. Now it's time to run through a
solution of 2 parts water and 1 part vinegar. Do this once or twice
with fresh solutions, then with a pot of fresh water. When the filter
stick is plugged up the sensor says its time to clean it, but most
people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
SOURCE: cuisinart CBC-00 series coffee maker seems to have lost power
Yes it has a short. Mine did the same. Cost to much to fix, cheaper To buy new one, if under 3 years old cuisinart will replace for $10 shipping charge. 1-800-726-0190
