SOURCE: alpine cdm-7833 cd car stereo code
I didnt think alpines had codes?
are you sure it has one?
sounds more like a connection problem
SOURCE: ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
SOURCE: After installing the alpine cde 9870 car stereo
In this situation 8 times out of 10 the problem is not with the radio, it's that there are factory amplifiers. Many cars have them, and most require a little work, or an adapter to get going. Tell me the year, make, and model of the car, and perhaps I can give you more info.
SOURCE: AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
SOURCE: I need to know how to get a dvd to play on my car
Go to RadioShack sumwhere like that an get a tr7 remote trigger it bypasses that s*"*t to watchem bubba
