SOURCE: sony ericsson p990i mobile with forgotten phone lock pin please HELP!
how to create a signature in sms
SOURCE: OUT LOOK LOST ADDRESS
I DON'T USE OUTLOOK, BUT FIRST WITHOUT A SOFTWARE PROGRAM TO RECOVER DELETE FILES, THINGS LOOK SLIM. YOU MIGHT TRY GOING INTO PROGRAM FILES>OUTLOOK AND SEE IF YOU CAN LOCATE THEM IN THE FILE FOLDERS. USUALLY DELETED FILES TAKE SPECIAL PROGRAMS TO RECOVER. A LOCAL REPAIR SHOP MIGHT HAVE THE SOFTWARE, BUT YOU NEED TO DECIDE IF IT IS WORTH AN HOUR OF LABOR AND A SERVICE CHARGE? IF YOUR ADDRESS ARE IMPORTANT, THEN BY ALL MEANS TALK TO A REPAIR SHOP TO SEE IF THEY CAN HELP RECOVER YOUR FILES. I HOPE THIS HAS HELPED YOU. PLEASE REPLY IF YOU NEED ADDITIONAL HELP.
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back.
Thanks mymomcallsme
SOURCE: forgotten user lock pin number
type on the main screen "##3282#"
go down to "advanced"
then press ''view''
click right 5 times, and it reveals your lock code
SOURCE: how do i get my cell phone off puk lock
Typically when a phone is asking for a PUK code it means you have tried to edit or set the secuirty pin code. Unfortunately these codes are already predefined by the sim card and the service provider. It gives you the sensation that you can set or change the code but you cannot. You get 3 attempts to enter the correct code after which the phone asks for a PUK code. When it asks for the PUK you also get three tries to undo it. Again PUK codes are predefined by the sim card and the service provider. If you call your service providers technical support number or customer service number they can provide you with the PUK or the PIN code.
>>>> Once the PUK has been entered in wrong 3 times the sim card is shot and deactivated. At this point you will need to get a new sim card to get your phone up and running again. If you have numbers stored to your sim card and not to your phone you will have lost them.
Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Reinsert the battery and power on the phone. Enter the last 4 digits of the IMEI number on the PIN entry screen. The last 4 digits on your IMEI number can occasionally be the service providers preset PIN for the cell phone.
Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code
