SOURCE: serger tearing stretch fabric
A new set of knives may be the fix you need. Sharp knives on a serger make a world of difference. I bought a new one for ours but I think a person could put a keen edge on the old one if they so desired.
SOURCE: I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
SOURCE: I am trying to do shirring with elastic thread on
I hand wind the bobbin but use regular thread for my top thread and set my machine with the longest stitch length. I put my tension on 3, my friend uses 4 but I guess it depends on your machine.
SOURCE: i am trying to shir
Have you wound the bobbin with the shiring under tension? you need the shirring elastic to be stretched somewhat as it goes onto the bobbin so that when stitched out, it relaxes and pulls the fabric up.
And yes, usually you need to tighten up the bobbin tension also to stretch the elastic some more.
The Ellure has a horizonal drop in bobbin so you will need to access this to adjust the tension. This may require unscrewing the two screws holding down the needle plate (metal flat plate you sew over). Take this off and now you'll see the bobbin holder area clearly. Look where the tension spring is, the little groove you pull the thread into when threading up. Is there a small dial just near this, about 7mm across? it will have a groove in the top and hopefully a + and - marking.
IMPORTANT: carefully make a note of where it is set now. Take a picture or write a little diagram down so you can get it back to normal setting. Use your little accessory screwdriver and carefully turn it one click to +, then test sew. YOu may need to turn it up 3 clicks to get the elastic stretched enough. Just make sure you know where to set the dial back to when you are done.
Also, remember you won't be able to shir heavy fabric, just light weight cottons work best.
I find that stitching lots of straight lines of shirring like you see tube bodice sundresses made in ready to wear is very hard, factories will have a machine that sews 20 rows at once. And getting enough gathers is trial and error with a domestic sewing machine.
Here's how I do it. Turn down top selvage edge of the fabric width you want to gather, turn down about 10mm and straight stitch around. Now on the wrong side with a sewing marker pen rule lines down from here across the fabric width spaced 1 cm apart. Now lie shirring elastic on these lines and stitch over it with a narrow zig zag stitch making sure not to catch the elastic with the needle. Start each sitching seam one cm from the raw edge of the fabric and finish the seam the same way.
Now I pull the elastic up from each side pulling all of them evenly until I"ve got it gathered enough. Now place right sides together and stitch the fabric into a tube catching the elastic ends in and securing them.
I hope this helps you out.
