Question about Measuring Tools & Sensors
What do the yellow and blue light mean on the meter
    Top Expert:
  • 5,436 Answers
What type of meter are we looking at?
Posted on Feb 25, 2019
SOURCE:
Adjust pilot light
check your gas pressure meter might be too small call gas company they will assist you
Nov 13, 2013 | Dyna Glo "" Natural Gas Heater Mn200tba
Blue light on battery condition meter is blinking. It doesn't stop.
hi the blue light is indicating a fault, now count the flashes before a pause, or does it just flash all of the time ?
Please keep me updated.
Regards
Dec 22, 2012 | Pride Pursuit Xl Heavy Duty 4-wheel...
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
I want to know how to test the driver side heated seat switch and wiring.
diagram #1
Diagra #2
I would start with testing the seat elements to make sure they do not have an open in them
Driver's side, unplug the connector to the heated seat element and test with a meter set to ohms .
Yellow w/ light blue stripe wire to violet w/ light blue stripe.
The most common point for the element to be open is on the seat where your thighs are at. Usually close to the center, it will have a small black mark on the seat mat / element backing.
Start with the meter check of the elements to verify. Good element will have a resistance, bad will show an open or infinity on the meter ( display when set to ohms, and holding the probes apart ).
Oct 01, 2010 | 2001 Ford F150 Styleside SuperCrew
What color wires mean what on the radio of a 1997 chevy blazer
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Doors Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Sep 30, 2010 | 1997 Chevrolet Blazer
What does it mean when the tv shuts off and the blue light flashes followed by the yellow
Ouch. Sounds weird. Do you mean the whole screen turns blue, then the whole screen turns yellow?
Try pulling the power cord from the wall a cycling the unit back on again.
Aug 15, 2010 | Toshiba 72MX195 72" HDTV
Yellow light on - N series router
the yellow light is for processing data
Jan 12, 2009 | Linksys Wireless-G Broadband Router
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
Trailer wiring
Hi Smokey,
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Jun 29, 2008 | 2005 Ford Five Hundred
Measuring Tools & Sensors Logo
75 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
