SOURCE: alpine cde-7853
hold down display button until time is blinking, about 20 - 30 seconds. to change hour press 5 button, to change minutes press 6 button. get time set then press display button again.
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
SOURCE: adjusting the time on an Alpine CDE-9852
Hello bitterswe834,
To set the time, do this:
1. Press TITLE repeatedly until the time is displayed.
2. Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
3. Use the volume control to adjust the hours while the time indication is blinking.
4. When the hour has been adjusted, press MODE.
5. Turn the volume control to adjust the minutes while the time indication is blinking.
Hope this helps.
SOURCE: Wiring schematic for Alpine CDE-7856
Download user's guide and go to page # 20 for wiring diagram.
