SOURCE: How do you pair your Insignia Headphones/ Headset
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
SOURCE: Can't pair bluetooth headphones with Insignia Pilot MP3 player
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
SOURCE: insignia tv needs to connect to my direct tv
You can find remote control codes at InsigniaProducts.com.
SOURCE: How do I pair insignia bluetooth headphone with
The Insignia headphones must be set to "pair".
With the headphones off, press and hold the power button on the headphones until the logo starts blinking red/blue. You are now in "pair mode". Have your Touch look for bluetooth devices and it should see it now.
Hope this helps!
