For the Kitchenaid KRFF507ESS01, to clear the power outage indicator (blinking "PO"), press the Measured Fill button on the key pad. That is the right-most button below the screen.
The manual for this refrigerator is available at Sears Parts Direct on the product page: https://www.searspartsdirect.com/partsdirect/user-manuals/krff507ess01-kitchenaid-parts-manual . The current link to the manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1507129L.pdf . See page 21 of the manual for information on the power outage indicator. Look in the right hand column. The manual is also available from Kitchenaid on the product page: https://www.kitchenaid.com/major-appliances/refrigeration/freestanding-refrigerators/freestanding-french-door/p.26.8-cu.-ft.-36-inch-width-standard-depth-french-door-refrigerator-with-exterior-ice-and-water.krff507ess.html . Scroll down (or use the link) to the Manuals & Guides section. Expand the section by clicking on the +. The direct link to the manual is https://www.kitchenaid.com/content/dam/global/documents/201504/owners-manual-W10772325-RevA.pdf .
I hope this helps.
SOURCE: Blinking Clean Light
run the 'normal' cycle without the hi temp feature
SOURCE: dryer wont start,
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
SOURCE: We have kitchenAid refridgerator model
A blinking temperature display usually indicates :
- a rise in temperature
- a failure of cooling system or a failure in the defrost circuitry.
In order to fix the problem keep the refrigerator doors closed for several hours. When the refrigerator reaches the set temperature the blinking will stop.
If the blinking does not stop it generally indiactes a problem with the refrigerator. The most common causes are either a failure of the cooling system or a failure in the defrost circuitry. In both the cases the refrigerator needs to be serviced.
SOURCE: Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
