Did you ask at Lenovo.com
login ask them, only they have books on this, we do not.
https://forums.lenovo.com/t5/English-Community/ct-p/Community-EN
Backlink profile
Backlink profiles
Backlink profile is one of the powerful SEO methods which we offer, rank up your website with our backlink profile service now.
SOURCE: could be a serious problem.
next time you get it running, right click on my computer>explore, click on 'C' drive, right click>properties>tools tab, then click error checking, if the option to choose repair found faults, choose it, then the system will run a drive check.
It may take a few hours as it sounds as though you have a bad sector on your drive, back up all docs immediately after the system as run a check and hopefully is up and running again
SOURCE: Lenovo -One touch recovery
Hi..
First you have to download this One Key recovery application from Levono's official site - lenovo.com. Just run the application and the installation process should help you thru..
I hope this helps.. please vote.
Thanks - billa
SOURCE: what does error 0611-204 mean? I just ran a pc
This code is a "invalid source" error. Sorry but that is all I can tell you about it. You can google that error code & it will tell you more.
SOURCE: not detecting
password is not working. i need to open it without formatting, because i have lot of important files inside it.
last two years i work with it smoothly, suddenly when i write down my password it shows invalid password.
please please give me the solution
thanks
shuvo
Numerous folks indicate that Windows doesn't register the Fn key as a keypress but using a tool that gives the ASCII value of a keypress I see the Fn key returning FF (perhaps FF in this case means 'not registered'). I also see that keys like Ctrl register with one ASCII code when pressed alone and another when pressed in combo with another key. Fn will only register when pressed alone, so Windows definitely isn't seeing the combo. This took a solution like AutoHotKey off the table.
I ran KeyTweak (which shows you the hardware scan codes of a keypress and the Fn key registerd as 57443). Using this program I remapped Fn to the Ctrl key; this worked perfectly. However, I suspect that because of the issue in #1, the combo of, for example, Fn + C did not execute a copy.
