SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
SOURCE: REMOTE CONTROL SYMBOLS?
Yes my unit shows a snowflake, bucket with squares (my husband thinks it is a fire bucket), fan (which we know about), and a sun. Does the snowflake mean-use in winter, or does the sun mean-heat ? We have a ComfortStar and the only booklet that we got is the technical manual which does not help us.
SOURCE: LG SPLIT SYSTEM AC.
Fixed fault by not only switching off AC unit at power point, had to pull out plug top & lead from wall for one minute. This must allow electronics to reset.
SOURCE: Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
