Please ask a question and please be specific as possible. This is not a question and has not enough information to answer a question if it was one- we could not begin to tell you why your unit is not working without more information.
when did it stop working
any noises
what were you doing when it stopped working
any smells
any warning messages
did the cameras loose power
too many questions so offer as much as you can when you do ask
good luck
SOURCE: linking cctv cameras over linksys router, ports
What is the problem exactly ?
For port list try this link :
http://linksysfirmwares.googlepages.com/portslist
Hope it helps
SOURCE: I have a sentient 4 channel cctv DVR with
have same unit colin and was a nightmare to sort but finally did it.
you need to set up port forwarding on your router and set up dydns account and switch on the service on your dvr. enter details on dydns page on dvr.
if you cannot log in via web address provided by dydns try entering your ip add with port your forwarding like this 89.79.89.87:9950
hope this helps
SOURCE: cannot delete events from Sentient N663HH 4 camera DVR system.
go to hard drive setup
you will need to overwrite over it.
go to overwrite on your set up and select yesto enable to overwrite harddrive when capacity is full
SOURCE: Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
SOURCE: I changed the admin password
I changed the admin password I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
you must use to keep backup of your videos.:)
