Discussion from several years ago at the link below that may be helpful, but I am not knowledgeable so you may need a Canon technician to diagnose and repair.
http://www.copytechnet.com/forums/canon/100585-e000202-error-message-canon-ir-2520-a.html
FIXYA questions from several years ago, but unsure if that is a correct procedure:
http://www.fixya.com/support/t26912144-solution_canon_ir2520_error_code_e000002
http://www.fixya.com/support/t25940263-reset_canon_ir2520_photo_copier_e000202
The problem Is located in the scanner section. Maybe the reading sensor is wrecked.
SOURCE: Canon ir2520 error E000002 where is the problem ?
problem with fuser.Go to the following to clear error:CLEAR<ENGIN<ERRCLR;and than turn off the machine and back ON.Check the connectors;replace the main thermistor;replace the fixing film;replace fix.assy. ; replace DC controller
SOURCE: Canon ir2520 showing error code 808. What is the solution?
Code
E808-0000
Description
Fixing drive circuit failure
- The heater does not turn on. - A fixing drive motor failure was detected.
Remedy
- Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the fixing drive motor. - Replace the DC controller PCB. - Replace the power supply PCB.
Hi galaulanu , I want to help you with your question, but I need more information from you. Please call customer servicefor Help and Support 1 8O5*465*751O Toll Free 24x7
