A few years back I bought a model 6906 phono/cd recorder.It worked fine for about a year then started to malfunction.I only used it to make CD's.
This happens when "finalizing" the CD to create the Table of Contents. Have these units been improved upon.I realize this unit is out of warranty but I still want have a unit with these capabilities.but certainly don't want to spend the money to buy another one if they aren't going to work correctly.
    New Friend:
  • 10 Answers
You need to clean cd laser lense and need lubrication track search tray.better to give service tech.
Posted on Feb 22, 2019
Testimonial: "How do I go about doing these things?"
AvioriX
  • 689 Answers
SOURCE: Getting a whine from CD player
Have you performed lens cleaning process?
Posted on Mar 06, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: novice
i/ve found that sony has the best single trays (and freq range)..i would stay away from multi cd players and any jvc (jvc freq range is horrible)...your speakers must match these componets....(bose, yamaha or customize )
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: Won't record
is the unit setup , sounds like the factory did a reset . go thru dm site for set up and repost
Posted on Aug 15, 2009
tthekraut
  • 374 Answers
SOURCE: which cd-r audio do I buy.
when you buy cdr's to use with the recorder be sure to go and buy "cdr audio". You may have problems with certain brands. It really is hit or miss but Sony discs should be fine with this player but try to get a small number of cheaper disks and try to see what works well.
There is a small chance that one brand may sound better(or some people say) but I have never had one problem like this from one to another.
Posted on Mar 17, 2010
  • 14 Answers
SOURCE: Philips Mini Stereo Model No.
Check for dust on the optical pick-up in the CD player. If you can, blow CLEAN air across it to remove dust.
Posted on Aug 12, 2010
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
After recording, I recieve a toc error c14 when I try to finalize it. How can I fix this problem?
There's a solution to the problem : the problem is one word..; '''Sony''. Throw the unit away as to my knowledge there is no company who makes discs that will allow a TOC (table of contents) to be written to the disc. All those Sony units were only designed to be accept Maxell CD-R Music Pro blank discs. They are unfortunately unavailable /no longer being produced. Step one: .Buy a Tascam recorder they accept consumer grade cds.. Step two: Boycott Sony as most of us who owned one of their standalone units didn't get two years of use out of it..including myself and most i've ever talked to about it.
Feb 18, 2015 | Sony RCD-W500C 5-Disc CD Recorder
How to get a copy of instructions foe anders nicholson E-6906
Request instructions directly from Anders Nicholson.
Dec 01, 2014 | Audio Players & Recorders
I need phongraph needle
If you look at the cartridge it should have a make and model number on it. If you put that into Google the stylus should show up.
May 22, 2014 | ANDERS NICHOLSON USB Turntable With CD...
Cd reader says disc not finalized
Don't know what a fwc100 is but you need to finalize the disc per procedure outlined in the manual- that writes the TOC (table of Contents) to the inner part of the disc which the unit reads right after the disc is recognized by the laser. If the disc is not finalized this TC is not written and you have a disc that can still be written to in certain burning units.
Sep 21, 2012 | Audio Players & Recorders
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
Mar 26, 2012 | Audio Players & Recorders
We have a DENON L.C twin transformer amplifier PMA-735R that has an input selector that freaks out now and again. Recently it has gotten worse, it just goes back and forth between tuner and cd etc. for...
Hi Readers to of Fixya,
This entry is January 22, 2016.
I own a Denon PMA 735R which I bought new in 1999, it is very good Amp; starting about a few years ago the input selector would occasionally randomly jump from CD to Phono to Tape etc., but would always end up back at CD so it was not terribly annoying until a few days ago when it started happening all the time. I am a very knowledgeable electronics person (I built musical keyboards at one time) so my thought was just that it was a dust problem and I started with that premise. I fixed it using an Electrical Parts Cleaner spray and here is how I did it:
I unplugged it, removed the CD input RCA cables and removed the L & R speaker cables and took it off its shelf and set it on a towel on my soft sofa; I removed the casing by unscrewing four big silver screws on the sides (my model is silver) and the three small black screws on the back top; I removed the Input Selector indicator knob on the front and the Record Out Selector indicator knob and the Volume knob, I then removed the small nut that holds the three of them tightly in place to the front panel; I then stood it on its back so that the front was facing up; I then sprayed my Electrical Parts Cleaner spray into the Input Selector indicator post liberally and then put the knob back in place and kept turning the indicator back and forth for a few minutes to work the cleaner inside the post down into the circuit board connection; I did the same with the Record Out Selector indicator post and I did the same with the Volume post; I then put the small nuts back on the three posts and tightened them; I then put the knobs back on the three posts; I then stood it back on its normal upright position and put the casing back on and then the screws; I placed back on its shelf and hooked up the cables and switched it back on and played my CD's, it has been working perfectly fine. The whole process took less than 30 minutes.I hope this helps.
Feb 20, 2012 | Denon Audio Players & Recorders
What does TOC read mean, the cd does not spin
TOC stands for Table of Contents. On a MiniDisc recorder or CD recorder, a Table Of Contents MUST be written before a disc is usable. On A player, a TOC must be read before the unit knows where to find the songs. Sounds like the laser is NOT reading the TOC, so you will hear nothing until that is corrected (clean lens or replace unit). Try a storebought CD, as perhaps is doesn't like your own burned CD's and most units built before 2000 will not read your own CD's that you make.
Jan 07, 2011 | Emerson MS3103 Shelf System
 Grubhead
Grubhead
Marvin
Marvin
