Question about Canon Office Equipment & Supplies
Hi we have a canon ir 3235 copier and the screen is no longer working its just black
    Master:
  • Canon Master
  • 751 Answers
Apart the blsck screen, Does the machine operates normally? If it does the problem is in the screen back light
Posted on Feb 25, 2019
fer_nan_14
  • 76 Answers
SOURCE: copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Posted on Mar 06, 2009
Cogz
  • 1326 Answers
SOURCE: Alignment of Tocuh Screen Panle of Canon Copier IR-6000/6001
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
Posted on Apr 02, 2009
canontech
  • 1219 Answers
SOURCE: I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
Posted on May 06, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
  • 140 Answers
SOURCE: My copier Model is Cannon
it is related o your fixing unit. check it.
Posted on Apr 26, 2011
Canon ir 3235 copier auto document feeder not working
What do you mean with not working?Can you give more details please.
Sep 05, 2018 | Canon Office Equipment & Supplies
Error code E000225-0001
i have canon ir 3235 continueing error cord 225-0001
Apr 28, 2014 | Canon ImageRUNNER 3235 Black and White...
Canon ImageRUNNER 3235 error code E000804-0004
Canon ImageRUNNER 3235 error code E000804-0004.. Solution for this error code is to replace the cooling fan.
Apr 24, 2013 | Canon ImageRUNNER 3235 Black and White...
Canon ir 3235 error e000196
error in communication between laser driver and dc controller,check the wiring and connectors
May 20, 2012 | Canon ImageRUNNER 3235 Black and White...
MY CANON IR 3235 HAS LOTS OF DUST IN IT HOW DO YOU CLEAN IT OR DOES IT REQUIRE A TECH?
if you have a toner vacum you can use it with no problem. If you don`t call a tech.
Nov 11, 2010 | Canon ImageRUNNER 3235 Black and White...
I accidently set user code on 3235 and can not shut off\r\nit blocks me from going into user tools
Are you taliking about Canon ir 3235?
SERVICE MODE:
* 2 8 * , select copier, function, clear, pwd-clr, and ok
Turn off/On
Jun 10, 2010 | Ricoh Office Equipment & Supplies
How to clear code on ir 3235?
wich code?
E000, E001, E002 You can clear under service mode:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
TURN OFF AND ON
Hope that helped
pls.rate
Apr 17, 2010 | Canon ImageRUNNER 3235 Black and White...
Clive
Clive
old marine
old marine
