Question about Vacuums
My eyevac sensor works then i wait 5 seconds and go to use it again and it won't turn on. I have to wait 5 minutes then it works again
    Top Expert:
  • 5,449 Answers
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassemb ly, complete refurbish, repair, installation every single t hing is covered
within seconds u can get the access and it's totally illustrative complete
Posted on Feb 23, 2019
5 Suggested Answers
  • 34 Answers
SOURCE: MY GEO TRACKER SHUT DOWN AFTER 3 MINUTE. I WAIT 5 MINUTE MORE
You seem to know enough about cars to rule out the obvious, like no gas, no spark.
If the tracker dies at stop signs or traffic lights, but you can start it and run it in between for a while, it could have an ECM failure, common for this age and year of tracker. Your symptoms are not exactly the same, but you may want to investigate this if nothing else works.
For more information on ECM failures google 'Geo Tracker ECM Failure'. The module can be purchased (rebuilt) on Ebay for about a hundred bucks. I have no affiliation with the guy that sells them.
Posted on Aug 11, 2009
stevexmas007
  • 699 Answers
SOURCE: truck star ok run for
do you smell any fumes?
Posted on Mar 27, 2011
jayhawke
  • 338 Answers
SOURCE: Engine won't start when it's
try running a good injector cleaner thru it- sounds as if you have a(or a couple)weeping injector,
try LUCAS injector cleaner- works on my sonoma
Posted on Jul 30, 2011
danoyachtcap
  • 2907 Answers
SOURCE: 1994 Honda Accord often won't restart after it stalls. After waiting 5-10 minutes it starts up again fine. What is causing this?
Could also be an intermittent coil, due to loose connections in the distributor.
Hope this helps.
Posted on Mar 30, 2015
My problem/// cleaner turns on for a around ten (10) seconds and then shuts off wait a few minutes and it will turn on but goes off again at ten (10) seconds?????
These units have a automatic resetting thermal fuse near the motor to help to protect it from burning up by running too hot. This will need to be inspected and tested to see if it's holding it's proper temps., if not it will have to be replaced. There should also be an inspection of the machine to detect what was causing the reset to shut down that quickly, so that can be repaired as well.
Oct 22, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My Kenmore vacumn won`t turn on . worked fine one minute then stopped. The light works on the handle but no vacumn
You probably have a sensor that needs attention and is clogged up so unclog and see if that takes care of it
Jan 12, 2011 | Kenmore Vacuums
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Protection light
it might be the bag or the sensor inside the machine.
Jun 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
