Question about Yamaha Audio Players & Recorders
How to turn on a turntable on Yamaha mc-600 sound system-- 50+ years old
Hook into phono or aux
    Problem Solver:
  • 11 Answers
If the turntable is a belt drive one then the belt must have deteriorated after all these years. Pull up (remove) the turntable disc platform. you will see a little motor shaft and the cut or deteriorating belt. You can order the belt from http://www.vintage-electronics.net/yamaha-mc-600-belt.aspx.
Please make sure that you clean the black residue left on the motor shaft and the turntable platform where the belt runs with isopropyl alcohol before you put the new belt on.
Posted on Feb 24, 2019
4 Suggested Answers
ricardok45
  • 135 Answers
SOURCE: My sunbeam mixmasters turntable is not turning
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
Posted on Mar 16, 2009
gbean009
  • 5 Answers
SOURCE: Minimal volume for my turntable
$20 at radio shack, and excellent quality.
http://www.radioshack.com/product/index.jsp?productId=2541471
Posted on Oct 23, 2009
  • 5603 Answers
SOURCE: I just bought 2 of
Don't mess with it and risk voiding your warranty. These are a servoed speaker and there is a problem with the feedback in it. Exercise your warranty immediately.
Posted on May 04, 2011
When I plug in my marantz TT-42 turntable to my Yamaha R-S300 receiver's phono input, I get a muddy and loud sound. I've tested the turntable with direct input to Bose speakers and it works fine.
If the turntable produces good sound with a line level input on another system, you have the turntable with the pre amp built in. That is why the sound is loud and distorted.
Mar 05, 2017 | Yamaha Audio Players & Recorders
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
Low volume on my technics turntable compared to other appliances
it needs a pre amp, or special phono input that will boost the signal, those old turntables have very low output lvl
Mar 07, 2013 | Audio Players & Recorders
I just bought a pioneer pl-420 direct drive record player and when i hooked it up to my samsung home theater system via the aux ports in front but when i play records the sound is too low im have to turn...
If the player has a MD/MC pickup head, you need to use an input suitable for MD/MC
(Magneto Dynamic/Moving Coil). If that is not available, you need to buy a standalone
phono pre-amp (pre-amplifier with RIAA-correction curve). Like the TCC TC-400G/L.
Example: See HERE and some info HERE.
Oct 07, 2011 | Pioneer PL-990 Turntable
I just bought 2 of the DSR 115 Yamaha speakers. One of them is NOW making a "light fluttering" sound from the woofer! Could this damage caused by my "Yamaha GQ 1031 b EQ"...
May 04, 2011 | Yamaha DSR115 Powered PA Speaker (1300...
No sound through the receiver
Note that on page 6 of the receiver manual (one of the models... you did not tell us which) says that... "the turn table must have an MC type cartridge OR use a seperate preamp or step up transformer"...
The MC cartridge is LIKELY a high output type which is NOT typical...
It MAY be you have too low a level of audio output from the turntable.
Dec 28, 2009 | Gem Sound Audio Players & Recorders
Can't seem to get any music from the turntable
Do you have the ground wire from the Turntable hooked up to the receivers ground terminal? it's a screw down silver nut and should be next to the Phono input. You are just lacking a ground from the turntable to the receiver. If you don't see a wire from the turntable, look around the chasis of the unit and you will fins it. Hope this helps
Jun 21, 2009 | Yamaha HTR-5740 Receiver
WEAK SOUND WHEN CONNECTED TO DURABRAND AMP
The electrical output from a turntable actually comes from the cartridge on the tone arm. Specifically, it's generated by an interaction between a magnet and a coil inside the cartridge. They come in two types, MC ("moving coil") and MM ("moving magnet") according to which of the two elements moves and which is fixed. MM cartridges produce more current but MC cartridges usually sound better. No matter which you have though, the total output is too low for the regular line inputs on amplifiers. Ten or twenty years ago, amps has special "phono" inputs. This would have a special pre-amplifier in it that would amplify the cartridge's singal to a level suitable for the rest of the amp. Most amps having a phono input only deal with MM cartridges, which have a higher signal.
I use an MC cartridge with an amp that doesn't have a phono input at all; therefore I needed to buy a special external phono pre-amp. I bought a Musical Fidelity X-LPS. But cheaper pre-amps do exist.
Apr 13, 2009 | Audio Players & Recorders
Carousel stopped turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
