If overhead valves, check valve lash. And/or may have sheared flywheel key.
To check key, remove flywheel cover/recoil so you can see magnets on fly wheel and the ignition module. Remove spark plug, use screw drive down cylinder, rotate flywheel and find piston TDC. (compression or exhaust stroke, doesn't matter)
If fly wheel magnets not near aligned to ignition module when TDC, likely flywheel key has sheared. Remove flywheel to confirm.
Just a thought your valves may need adjustment.
SOURCE: 92 dodge stealth twin turbo v6
Check your grounds guys...if even ONE ground is loose or corroded from the block, she'll act up...especially more when warm. Another good place to check is under your console (behind radio), this is where your main ground actually connects (weird yes) but we've rebuilt a stealth and had this problem....turned out to be the ground on the metal chassis behind the radio.
SOURCE: hard start when air temp is cold, backfires when warm
Try this, remove (MAF) Mas Air Flow sensor,(be sure key is OFF) so you don't set a trouble code when disconecting wire conector, with some throttle body/air intake cleaner from the outlet side of MAF, spray the sensor clean, let dry, reassemble.Remove snorkle from throttle body, and with a old tooth brush, clean throttle body& plate with cleaner, may take a couple of cans if throttle is badly 'coked' up. Hope this helps.
SOURCE: Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
First of all; if your engine is that new, take it back where you bought it and have them make good on it.That being said, if you're priming it and it starts then dies, then it's not getting fuel on its own. You've run some bad gas thru it or let gas sit in the carb (Ethanol Gas=BAD) and it is clogged up somewhere. Easy fix if you're so inclined. I'll link you to a good video that shows you how to do this carburetor. Just be very aware of how the linkage to it is hooked up (take a digital photo, trust me). Ignore the first part of the video about removing just the bowl. Take that baby off and go THRU it with a good carb cleaner. Remove the bowl gasket and set aside, as carb cleaner and rubber are not compatible. Here's the video link. I hope this helps; I know it's frustrating; I go thru this every day and keep coming back for more! :
http://www.youtube.com/watch?v=ArCAivgAyww
Best of luck. James
