The motor wont do anything but hum. - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 6,278 Answers
Could be the capacitor, or the motor itself, or drain pump, or transmission. Need model and more info.
Posted on Feb 22, 2019
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
1999 cadillac seville washer fluid wont come out
If it makes a humming noise but nothing comes out, look for a broken fluid line or a clog in the line near the motor. If it doesn't make any kind of humming noise, then it's likely the washer motor is no good. you can replace the motor fairly easily as long as you can get the washer container out of the car. The motor is attached to the container and is usually held in by a couple of screws or clips. First thing to check though would be the nozzles themselves on the hood. Use a needle and poke the holes in the nozzles and see if anything comes out. Sometimes they get clogged up and nothing happens.
Nov 07, 2013 | 1998 Cadillac Seville
Maytag
Locate your motor after taking the plug off the wall mains. Something should be clogging your motor......
Apr 23, 2013 | Maytag Washing Machines
Fills with water and then stops makes a humming sound ,then stops all togther wont do aything spin or drain
sounds like an induction motor. start winding or start capacitor not starting to turn motor, This will make motor hum. Do not know m/c in qestion. Switch on and as soon as pos try to turn motor careful not to use hands or anything that can injure yourself with if it starts to spin.
Oct 29, 2012 | Whirlpool WTW5521S Top Load Washer
Motar just hums wont do anything but hum
If the motor just hums and there is nothing stopping the motor from spinning then it is smoked and will need to be replaced. Wish I had a more happier answer for you but I don't.
Regards, Tony
Apr 19, 2011 | Dishwashers
Hi, the lights come on but machine wont do anything. Is there anything i can check before calling an engineer?
hello check the door interlock with the power off make sure the door's got a good connection also check the belt might have snaped or come off if theres a humming sound from the motor the brushes might be the cause. these are made of carbon and wear down can cause the motor to stop working on the motor there are 2 plastic blocks sit either side of the motor they just slide out hope it helps
regards
shaun
Mar 19, 2011 | Candy Washing Machines
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 | Dishwashers
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
