Question about OMNI Computers & Internet
BIOS FOR OMNI 120 1050 CANT GET INTO SETUP WITHOUT SETUP PASSWORD BUT BOOTS TO WINDOWS
  • OMNI Master
  • 8,836 Answers
Check with HP to see if they have a solution, but without password, it may be impossible.
https://support.hp.com/us-en/document/c03059228
Posted on Feb 21, 2019
  • 233 Answers
SOURCE: can nor remove bios password from a amilo laptop
Take out the battery for longer. It seemed to reset by indication of checksum error, but for an odd reason its still passworded. Remove battery and this time short the battery contacts on the motherboard and make sure no power or battery is in the machine. Then replace the battery and give it a shot.
Posted on May 06, 2009
LMITC
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Posted on May 27, 2009
cbeyer286
  • 5 Answers
SOURCE: omni 3740 SYS Mode file group 1 password?
Where did you purchase the machine from? Or do you know what companies have downloaded onto it previously? They must have changed it at some point.
Posted on Jul 16, 2009
  • 74 Answers
SOURCE: Can anyone help me on how to reset the Bios
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 30, 2009
melaiii
  • 35 Answers
SOURCE: Phoenix bios setup utility is requesting a password
Actually, if you do not know the password it is best not to guess because 3 wrong guesses would result to losing the data on your hard drive forever.
the simplest way to remove a bios setup utility password is by removing the cmos battery. computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
1. open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. please refer to the picture below. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
2. Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
3. Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
Posted on Apr 14, 2010
I have an Omni Book 500 That wont let me change the bios is there someway to get around that ?
I am guessing that you are attempting to use a non supervisor level password. There is usually a facility to set both a user (restricted function) password and a setup password (administrator rights access). You may need to reset the passwords within the bios setup.
Apr 10, 2014 | HEWLETT-PACKARD Omnibook 510...
Tip
Reset Windows 7 Password Using CD
Many of methods are available to reset Windows 7 Password. The popular method recovering forgot Windows 7 Password is Using CD.
Easily without data loss.
How to Reset Windows 7 Password? Now we divide into two steps to complete.
Step 1: Download Password Unlocker tool and create a Windows 7 Password reset disk using CD.
Download Windows Password Unlocker from Password Unlocker Official site
Decompress the Windows password unlocker and note that there is an .ISO image file.
Burn the image file onto an blank CD with the burner freely supported by Password Unlocker.
Important : " How to set BIOS to boot from CDROM?"
1) When your computer is powered on, you can press "F2" or "Delete" during the boot to enter BIOS Setup.
2) You will see some similar BIOS screens like this below, which is varying according to different computer manufacturers. Windows Password Recovery.
3) Choose BOOT option > select Boot Device Priority > set 1st Boot Device to [CDROM] & 2nd boot device to [Hard Drive]. Press "F10" to save it.
An .ISO image file of Windows 7 Password disk have been already completed.
Step 2: Reset Windows 7 Password.
Insert the newly created CD (An .ISO image file of Windows 7 Password disk) into the locked computer and re-boot it from the CD drive.
After launched the CD, a window pop up with all your account names(if you have several accounts); select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
NOTE: To reboot your PC with a CD/DVD disk, it's necessary to change your computer's setting to make it boot from the CD/DVD.
1) When the CD/DVD boots, you'll see Windows Password Unlocker 4.0 is initializing.
2) Select the user name of your Windows 7 account whose password you want to reset.
3) Click "Reset" button to process. A message box "Password of Administrator reset" will appear After a few seconds.
Now, you can login your Windows 7 PC without password.
Solve all your problem within a few minutes. Easy, Importantly, without data loss or reinstalling!
on Jun 01, 2010 | Audio Players & Recorders
How do i reset bios setup password
Hello
There will be disc type battery that supplies the Bios IC. You can locate it very near to Bios IC. Taket out, and reinsert it after 2 minutes or so. All the previous bios settings, including time will be resetted to orginal factory default. You have to get into Bios setup, by pressing 'Delete' Key, while boot up to get Bios setting window. If you don't know how Bios settings, refer to its user manual. Sometimes the details may be there. If not, without proper knoledge, do not attempt to do this work. OK
Feb 05, 2012 | Acer Aspire 3690-2196 Notebook
I forgot my bios password. and i cant access my pc. can you help?
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen, press ctrl>+alt>+del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2-Some computer systems have a setting in the BIOS Setup to disable the password. The BIOS Setup is accessed with the F1, F2 or DEL key during boot up. If you have forgotten your password, most systems have a jumper on the motherboard that can be pulled off to clear the password. If there is no jumper available, you can also remove the battery for 5 minutes to clear CMOS.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Samsung R519-53S Notebook
I locked my hardrive and cant get into it now.......how can i unlock it
Need more information. How did you lock it? In the BIOS?
Assuming you did this in the BIOS you will need to enter the BIOS by hitting F1, F2 or DEL while the computer is booting in BIOS. Sometimes you will see the BIOS key noted on the bottom of the Boot screen. On the first BIOS screen check to see if your HD is listed. If so go to the BOOT screen. On the BOOT screen check the boot order. To move the HD to the top click on the HD and click on the "+" key to move it up of select it if you get an options window. In the BOOT SETTINGS screen click on the HD to varify that the correct HD is listed. If more than one HD you can move the boot drive up by using the "+" key or options window. Check your other settings. When done hit ESC and go to the last screen and select to SAVE and Reboot.
If you locked yourself out at the Windows Password screen. If you are using Windows XP Home, reboot and hit F8, F10 or F12 during BIOS boot. Select SAFE MODE. When Windows open go to the Control Panel - Users and delete the users. This will remove the passwords. Close windows and reboot computer. Windows will now start and open without passwords. If you are using XP Pro you will need to take the computer to a Tech who will have a Password Disc to clear the passwords.
Apr 14, 2011 | Computers & Internet
Can not sign in
if you mean that you cant login to your computer because you forgot your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change fist boot back to your hard drive) Hope this helps
Apr 02, 2011 | Computers & Internet
My laptop was running a bit slow and i pressed f8 when my laptop started and i set up a password, now i cant turn it off everytime i turn my laptop on i have to type the password in, before windows starts...
I think you need to enter the bios. when the system boots look for the message to enter the bios or setup . it might be "del" you need to do it before the message disappears and sometimes the message does not appear for long, inside the bios setup you should be able to disable password requirement.
Dec 19, 2010 | Computers & Internet
When my acer aspire 9300 laptop is turned on it says password i dont no what it is can u help
Well, I am providing you four tips which you can consider to recover Windows administrator password if your forgot or lost it:
TIP 1 - Use password reset disk
Windows-based system was designed to be able to create windows password reset disk without any other third party tools. So you can make use of a password reset disk to reset your Windows password in case you lose or forget your Windows password.
TIP 2 - Restore the operating system
Windows password recovery can be performed by restoring the operating system. Since restoration leads to data deletion, the solution can only work if you have a clean and updated backup of your hard drive data stored somewhere else.
TIP 3 - Use Windows Boot disk
The boot CD for Windows can be used to reset the administrator password. This disk enables you to repair Windows OS, thereby, setting your administrator password as blank.
TIP 4 - Use password recovery software
This is considered as the best windows password recovery solution, however, is to download a third party software. These tools enable you to reset Windows administrator password without posing any threat to your hard drive data. Among so many password recovery software, windows Password Recovery 6.0 is an easy-to-employ application which can be used to reset lost or forgotten password of any Windows system. Now execute the following steps to recover your lost windows password if you haven't prepared anything.
Step1: Login to a computer that can link to Internet. Download Windows Password Recovery from
http://www.recoverlostpassword.com/products/windowspasswordrecoery.html and install it on that PC.
Note that: there is an .ISO file. Burn the .ISO file to a CD/DVD or a USB flash drive
Step2: Get out the newly created CD/USB and insert it to the locked computer.
Step3: re-booted the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old passwords were removed.
Step4: logon PC without password and setting the new password
Sep 24, 2010 | Computers & Internet
Locked out
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Jan 20, 2009 | Dell Inspiron XPS M140 Notebook
Acer 3089
hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Jan 10, 2008 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
21 people viewed this question
Top OMNI Computers & Internet Experts
Rajendra Singh
Rajendra Singh
ray gallant
Terry
Terry
Are you an OMNI Computer and Internet Expert? Answer questions, earn points and help others
